efi help
From Melbourne, Australia
i am geting a efi from an nissan et turbo but i need a Computer can i use a Computer from a nother car
Posted on: 2005/7/30 15:28
When the going gets tough the Datsun keeps going😋
Re: efi help
From T'ville
early delco computers are the easies to adapt if you cant afford an after market one . these were in V/N,P,R and pulsars that had the holden engine i think n13
all u need is a good computer and a pin out map
then about ten different colour wire and you can make your loom or get a auto electrician to make one up
when it' s close to running you can get chip written for it
probably cheaper to buy a link orr wolf or something like that
Posted on: 2005/7/30 18:04
Re: efi help
From Lethbridge, AB, Canada
is it from a CA18ET? 84-88 Gazelle? If so you could use that ECU, they arnt great but I think it will work vor your application...
Posted on: 2005/7/31 1:45
'73 Datsun 1200 Sedan Turbo A12
Re: efi help
i will get a picOpen in new window
Posted on: 2005/7/31 5:03
Re: efi help
From T'ville
these were E15t
I have been looking at these engines as the next generation replacement
good ones (any) are hard to find up here
not sure of the resistance of these injectors , might have chack this before you choose a computer .
Posted on: 2005/7/31 12:30
Re: efi help
delco is pretty easy and cheap (one from JE camira fitted to mine)
resistance of injector can be changed quite easily by fitting a resistor in-line for each injector
how are you planning to fit the injection??? to an a-series i pressume?
Posted on: 2005/7/31 17:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
