Master and Booster
I'm using S13 front rotors and calipers on 120Y struts and have also fitted TRX discs to the stock ute diff. I have made up an adaptor plate to bolt up to the original two bolts on the firewall and then to a Sunny booster which has the original S13 Master Cylinder bolted to it. You just need to file out the mounting holes on the S13 master a little bit and it bolts straight on to the Sunny booser. Although I have all the parts, I have not completed bolting it all up. So can't vouch for how well this package all works. But I've been told from a reliable source that it will pull up a CA18DET powered 1200 very nicely.
Good luck!
Posted on: 2005/8/2 10:30
