South-Africa CCG Nissan 15A/Datsun 120Y ute
Quite a regular
From South-Africa Pretoria
Hi,I have a 1976 120Y ute (bakkie),I fitted a nissan 15A motor, could somebody please help me with the valve clearance spegs on the 15A motor? Is it the same as the 14A motor? Thanx CCG
Posted on: 2005/8/10 1:14
Re: South-Africa CCG Nissan 15A/Datsun 120Y ute
From Strand, South Africa
check out the tech section for posible more info
If there is a difference it won't be by much.
Posted on: 2005/8/10 14:57
Quite a regular
Thanx Losadel, I got some specs for the 15A Head bolts 69nM-74nM,and Valve Clearance (hot) int-0.35mm exs-0.35mm, its the same as the 14A. Thank you for the reply! CCG
Posted on: 2005/8/10 22:17
From Launceston, Tasmania
by the way the A series datsun motors have the A before the engine size.
So it's pronounced A15 and A14 not 15A and 14A.
Just thought I'd let you know.
Posted on: 2005/8/12 13:05
12A is mazda
A12 is datsun
Posted on: 2005/8/12 17:04
Quite a regular
Thanx! I dit not know,
Posted on: 2005/8/12 22:09
