battery boiled dry - sulfurous - thought it was the fuel :(
Quite a regular
From Perth Oz
has anyone ever had their battery boil dry - I though I had a bad batch of fuel but I checked the battery the otehr day and was baren after 2 45min drives - I dont drive it much so thought the ute just needed a good drive to charge the battery. So I've topped up the cells with distilled water but the inside looks cooked so thinking a new battery is the go - damn thing decides to do this when she heard I was selling her!
The radio started cutting out too so I will experiment by removing the radio fuse and see if it happens again. if it fixes it I guess the new owner will need to get a new radio fitted........
thoughts? experiences??
Posted on: 2005/8/16 11:48
Re: battery boiled dry - sulfurous - thought it was the fuel :(
From Christchurch. NZ
Sounds like you have a crook regulator, letting the alternator overcharge. Make sure that the charging voltage doesn't go over 14.5 volts
Posted on: 2005/8/16 11:51
From Alabama, U.S.A.
yep it sounds like an overcharging alternator!! That happened to me one time traveling 70 miles away battery blew the caps off the top , battery acid all over the plug wires . looked like christmas lights under the hood ,lol
Posted on: 2005/8/17 0:53
This happened to me last year -- and it was not overcharging. My mustang was in the garage for six months without driving, then in the spring the battery wouldn't charge up and then I discovered it was out of water. I forgot that checking water level was part of regular maintainence. I had to buy a new battery. The plates were sulfurous-looking and after I added water, it still wouldn't take a charge.
Lesson learned: check the battery levels every few months and top up as needed with distilled water ... or risk a battery going bad before its time.
Posted on: 2005/8/17 4:12
Quite a regular
From Perth Oz
OK thanks for the advice, ideas, stories, and experiences.
I had the alternator serviced, rebushed a few years ago so that is fine, I guess I was just slack and did not check the water level, I thought something may have been short circuiting but that would blow a fuse instead of boil the battery..... so I'm off to buy a new battery - small price to pay to sell the little beastie.
by the way someone asked if I have any spares, I have some extractors and the orginal carby that are not fitted but the new buyer may want them also, depending on what they want to offer...
thanks again!
Posted on: 2005/8/17 7:12
From Warburton vic
Get the alternator checked out properley. There is a bit more to an alternator then fust brushes & bearings. There is things like diodes & rectifiers that fail. So take it to an auto elec cos if its over charging you will only cook another batterie.
Posted on: 2005/8/17 10:24
If you're worried about overcharging, there's no need to take it to a professional to find out. Just put a voltmeter on, rev the engine just a bit, and if it stays at 14.5 volts or below it is fine. Even better, install a permanent voltmeter inside the car.
Posted on: 2005/8/19 4:21
