5-Speed Box
From Brisbane, Australia
I have a 1200 Ute, with an A14 engine. Currently i have the original 4 speed gearbox, and i am really after a 5-speed. I was wondering if you guys know which ones will fit and what is best. 120y's or anything? that is if i can find them too
Posted on: 2002/9/5 11:56
Re: 5-Speed Box
From Melbourne, Australia
as we ask all new members cause no of them put it in their profile (maybe you should advise it Daniel or Pedro when people are filling out there profile)
WHERE ARE YOU?
to answer your question though sunny or b310 (same car diffrent names diffrent places) came with a 5-speed which will bolt straight up except you may have to modify or make your own rear crossmember for the back of the box to sit on, these are getting hard to find in Aus can cost $800-1000 in NZ will cost a couple of hundred but also thinning out and i believe they are easy enough to find in America not sure of cost
Posted on: 2002/9/6 1:09
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: 5-Speed Box
From Western Sydney
Without ever hopping too far under the car to tell, i'm guessing I have one of these. Modified tunnel and cross member.
When I get enough time I will eventually pull out the a12 sunny with the little holley and the 5 speed out and sell them!
Posted on: 2002/9/9 13:41
www.datnet.org
Re: 5-Speed Box
From auckland, new Zealand
i have a 5 spd in my coupe its out of a sunny i think but i cant remember. but all of the gearboxs are getting old now so you should get it reconditioned really so its just like new. im saying that because mine is ####ed and it needs a reco pretty badly.
Posted on: 2002/9/10 2:46
Re: 5-Speed Box
From Castro Valley,CA USA
I got tired of lying in the mud every year or so at the junkyard looking for a 5spd. The last one I pulled, I took staight to the gear shop and had them do an overhaul. They replaced the bearings and seals and its been ok for about 4years now. The last 3 5spds that blew up on me failed because of the bearings. I also dont try and launch like I'm at the drags at every stoplight anymore, either. that helps
Posted on: 2002/9/10 8:00
Re: 5-Speed Box
From Western Sydney
Mines unreal, no probs at all... not going to spend anything on it if theres no bad signs
Its been well looked after and hardly see's many K's anyhow.
Posted on: 2002/9/10 13:54
www.datnet.org
