Browsing this Thread:
1 Anonymous Users
E15 To rear wheel drive help.. |
From Radelaide, South Australia
Hey, Trying to find someone that makes adapter plates to suit the ET Pulsar e15 to an a series or supra bellhousing, I have got the clutch organized, and using coil packs will eliminate the dizzy going through the fire wall, its just the starter motor and some other little things that are my concern.. Any help would be great.. Cheers, Dane..
Posted on: 2005/8/29 12:49
Re: E15 To rear wheel drive help.. |
From Alabama, U.S.A.
The E-15/E16 will bolt straight up to the A-14 tranny. One bolt will not line up but easy to adjustto fit.As for the starter, all you have to do is use the A-14 starter.I did this in a 79 b-210 but I cut a hole for the dizzy. What exactly did you do about the dizzy. Crank sensor?
Posted on: 2005/8/29 23:15
yeah crank sensor, thanks for the tip mate.,
Posted on: 2005/8/30 6:02
