when to shave the head on re-assembly???
From Melbourne, Australia
under what conditions should the head be shaved whem re-assembling to block? (a15-so alloy head)
is it only if blew head-gasket?
always?
if obviously warped only?
i ask cause im switching block at the moment, and wondering if i should have it done, i dont want to do it as it will drop the valves and raise compression (not good for turbo) oh yeah, and it costs money...
Posted on: 2005/10/2 13:48
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: when to shave the head on re-assembly???
Run a straight edge over the head & see how much it is out of true with a feeler guage.
My Sunny [B310] manual says that the maximum thickness feeler guage that you can slide under the straight edge must be less than .004" or 0.1mm. If the out-of-true is less than these figures, you can bolt the head back on.
This is for a stock engine. For a boosted engine, i would personally cut that measurement in half.
Lay the straight edge diagonaly along the length of the head [both diagonals as well as straight along] & check it in many places, but between the combustion chambers is always a good place to measure
Always check the head for true whenever it is off. It's quick, easy & cheap to do & it could save you needing to take it off again if problems develop.
Posted on: 2005/10/2 14:44
Love your Datsun.
Treat it well.
cheers
Posted on: 2005/10/2 14:48
1200 Coupe Rallycar
I can give you the name of a good guy in Springvale if your going to go ahead with it.
Cheap too, he charged me $125 for head and block shaved, hone and all hot tanked.
I thaught that was pretty good.
Posted on: 2005/10/3 2:17
