nitrous on an a14/a15?
From sacramento california
has anyone ever used nitrous on an a series engine? if so, how well does ir work. i want to instal a fogger set up on the air cleaner case into a webber 32/36. does that sound good or bad?
Posted on: 2005/10/25 2:08
Re: nitrous on an a14/a15?
Posted on: 2005/10/25 2:50
From Cyberjaya, Malaysia
that'll be stage 1 NOS system... using dry shots..
the main advantage is that it'll cool the intake air (up to 20C cooler).
just make sure you start it low... a 5 - 10 shot will be good enough in stock
Posted on: 2005/10/25 3:02
are you running fuel injection? what is the mods on your engine?
it'll be better to run a direct injection NOS where the system will squirt fuel and NOS together so that your engine won't run on fuel starvation (lean) when NOS is activated
Posted on: 2005/10/25 3:05
nitrous creates a better air fuel mixture, thus better feul attomization. if i run a wet fogger system with is a fuel and nitrous nozle into the intake of the carb. would a 50 hp shot harm my stock motor?
Posted on: 2005/10/25 3:11
From bend oregon
how many miles are on the motor probably 25hp shot is plenty on a stock motor
Posted on: 2005/10/25 3:27
well i bought it and the odometer said 34660 im geusing its 137000 or 270000. i cant tell. but by the shape of the car i geuss 137000
Posted on: 2005/10/25 4:09
From bend oregon
137000 or 237000 mine will be finished tommorow for the motor and a year for the body
Posted on: 2005/10/25 4:14
From bend oregon
the last motor i built i could pull 7200 rpms all day long but i sold it and want to find it for the motor 80 210
Posted on: 2005/10/25 4:18
From Adelaide, South Australia
I'll post a photo later if I have time with an A15 with NOS.
Posted on: 2005/10/25 4:40
"Anyone who has never made a mistake has never tried anything new"
Albert Einstein
Put stupid oversized photo here>>
