How do you to install an electronic fuel pump on a a12?
From Melbourne, Australia
geday im doing a blow through setup on my a12 and was woundering on how do you to install a electronic fuel pump as i dont want the fuel getting blowen back down the fuel line.
cheers
Posted on: 2005/10/24 12:48
Re: How do you to install an electronic fuel pump on a a12?
Not too shy to talk
From Sydney, NSW, Australia
Posted on: 2005/10/24 12:52
Thanks urban_myth my next question is how do i go about actually installing it.
Posted on: 2005/10/24 13:01
you kinda need to explain how you plan to set it up
installing the pump is as simple as a positive and negative wire, an in and out fuel line, and some sort of bracket to hold it down
and you need to remove/block the old mechanical pump
but without knowing what pump and regulator you plan to use its hard to give any further advice
Posted on: 2005/10/24 14:17
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Yes, as 1200rc says, it is super-simple. I used a (79 honda?) pump, it has it's own bracket. One wire. No regulator (it's a 5-pound pump). I simply bolted it to an existing bolt on the firewall. I hear you can even leave the old pump on the block, although removing it looks cleaner.
Here's the one I used:
Jidosha Kiki KK fuel pump
This one gives me ideas...
Datsun B310 (also Subaru) electric fuel pump
Posted on: 2005/10/25 7:59
Ohh yeh sorry i plan to use a Holley Blue fuel pump and regulator. where aboust do you hook the wires up to they cant jst go straight to the battery cause it wouldbe pumping all the time yeh?
Posted on: 2005/10/25 8:53
I connected mine to the + side of the coil resistor (or for electronic ignition, straight to + side of distributor). This is only hot when key is on Start or Run.
But for the Holley Blue, please follow Holley's instructions. If you don't have them, check Holley's web site. It may draw too much current for the coil wiring and may need a relay.
Posted on: 2005/10/27 4:53
From Castro Valley,CA USA
This is how I wired my car in anticipation for an electric pump. The oil pressure switch turns on the fuel pump relay when there is oil pressure. With no oil pressure, the relay turns off and the dash light turns on.
I submitted this pic for a related post that I'll try and find.
edit- here it is
Re: Elec Fuel Pump
Posted on: 2005/10/27 9:36
From Alabama, U.S.A.
If you read the directions carefully they also recomend that you mount the pump as close as you can to the fuel tank.
Posted on: 2005/10/27 22:09
