1000 disc brake conversions??
What is the easiest disc brake conversion for a 1000, and what sort of dollars would you be looking at to do??
Posted on: 2005/10/25 14:53
Re: 1000 disc brake conversions??
From Perth
Posted on: 2005/10/25 15:08
From Melbourne - Werribee
they arent too hard to do really
all you need is a shallow offset disc so then u are able to make a flat plate that can bolt through the drum backing plate bolts
i have seen several laser type setups but the last one got the offset correct by using 200B hubs i think
i personally have put silvia setup on one but that was a heavy conversion and complicated as the disc offset was large.
currently i am finishing up a wilwood race type setup which worked out really well apart from the wheel to caliper clearance
all the pics are in the yahoo group and being a 1000 guy u should join cos its tumbleweed over there
http://groups.yahoo.com/group/datsunb10/
all the pics of what i have done are in the bennys thou folder
there is also a nice conversion that dattoman is selling and it is on his website
http://members.iinet.net.au/~dattoman_1000/index.htm
its all there too and he should join the yahoo group and more importantly my msn as i bet i can help him out
u are of course welcome to hassle me on msn too
blue510fj@hotmail.com is the email to find me on for msn
you can message me here too if you would like
ben
Posted on: 2005/10/25 15:13
damn u dattoman u beat me to it!!
its all good
ben
Posted on: 2005/10/25 15:15
From Canada, B.C , Richmond
Where are you located? i did it with a multi
Posted on: 2005/10/25 19:37
From sydney
Old Sigma rotors and calipers work pretty well without too much modifying, not as easy as Dattomans conversion, his is an actual bolt on, you can find the details if you use the search bar.
Posted on: 2005/10/26 0:19
