« 1 ... 8 9 10 (11) 12 13 14 ... 17 »
Re: no turbo no nos A 14 13.85 quarter mile
13.85 at sea level on a streettrack.....Lets see what happens on Tarlton or Wesbank which are international race tracks.
Posted on: 2005/11/28 16:29
From Canada, B.C , Richmond
Why don't we just turn this in to a mythbusters episode ?Why don't we just turn this in to a mythbusters episode ?
Mythbusters rocks btw
Posted on: 2005/11/28 17:21
sunny wrote:
I dont know what the aussie ET pulsar turbo ran ( if someone can tell me that would be great)
16.7 ish
Posted on: 2005/11/28 22:23
Datsun 1000 ute - Building (slowly)
Datsun 1600 13B turbo - coming soon
From sutho shire, NSW, AUS
minish, what diff ratio are you running?
i have heard of the Micks Mororsports Gemini running 11 second quarter miles on a stock NA G160 block (obviously heavily worked). It has a 5.25 diff ratio or somthing rediculous like that. If 11s are possible in an NA Alchohol buring Gemini. 13s are possible from a streeter with a stupid diff ratio.
Well i rekon anyway.
Elliott
Posted on: 2005/11/29 2:16
From Little Rock, AR
Mr. Matsuoka's drag Sunny Truck runs low 13's with an A15, but he's also usually got a small shot of NO2 on it. I got a chance to drive it once and the way it felt I believe it could probably stay in the high 13's off the bottle/NA, it was pretty dang quick. But this is also in a heavier truck...in a lighter sedan you'd be a little better off, I think it's definitely possible to run an A14 1200 sedan this quick naturally aspirated but it's gonna take a lot of work to set it up right and tune the suspension, engine, and gears properly. With those times you must be getting decent traction....it would give my SR20 coupe a good run at a quarter mile track just cause I can't get traction
Posted on: 2005/11/29 6:51
From South Africa
hi
we running a 4.3 alfa limited slipp
thanks
minnesh
Posted on: 2005/11/30 21:06
From South Africa
even if we run a 14.85 up country i still think its great for a 1400 normally aspirated
8 valve pushrod engine with a thirthy yearold
technology
minnesh
Posted on: 2005/11/30 21:11
From South Africa
what u mean yhat the SA posts are fishy ??????.
Posted on: 2005/11/30 21:16
From South Africa
with no disrespect as u asked
toyotas... 16 and 20valves
bms
golfs 2L
opels 2L
even some datsuns as well
all of these were on an official drag race as we do not race illegally.
thanks
minnesh
Posted on: 2005/11/30 21:22
From California
Uh oh ... changed diff. ratios on us.
Posted on: 2005/11/30 23:31
