Converting from points to electronic
Quite a regular
From Adeliade, Australia
Had an A12 in my Sunny, converted to an A15. A15 has electronic distributer! Still have the original coil and ballist resistor mounted which was running to the points distributer on the original A12! What do I have to do? Do I remove the resister and run the positive and negative striaght to the distributer????
Posted on: 2005/11/29 22:31
Re: Converting from points to electronic
From SE Melbourne
You will not need the coil and ballast resistor anymore....
Check out this Tech section link for details on re wiring for electronic ignition
http://datsun1200.com/modules/nsectio ... p?op=viewarticle&artid=65
Good luck
Posted on: 2005/11/30 4:19
Mildman, Datsunless
