Cable to Hydraulic Clutch Conversion
From Brisbane
I have done an SR20-DET conversion into a Datsun Sunny Coupe, Now my clutch is sorted and works and also feels heavy. Does anyone know how to soften the pedal???? Or if you used a different setup. I used a 180SX clutch master with the 180SX slave...maybe its a heavy duty. I haven't opened it yet.
cheers
Posted on: 2002/10/21 17:15
Re: Cable to Hydraulic Clutch Conversion
From Perth
are you using the 11/16 or 3/4 slave ?
If you have the 11/16 and swap to 3/4 it will make it slightly lighter but wont travel as far so check clearance.
If its already a 3/4 you could get it made larger and sleeved to say 13/16.
Posted on: 2002/10/22 13:35
From Brisbane
Yeah I was checking on that...going to 3/4 would make it easier, only I am not so sure about clearance. I should just try it and see how it goes...can't lose.
Posted on: 2002/10/22 16:28
