wanted specs on the 4agze motor
hi just wondering if you could help me out
where putting a 4agze motor into a datsun 1200 ute and want to rebuild the mtotor but need spec's on the motor and any other advice
Posted on: 2006/1/7 3:17
Re: wanted specs on the 4agze motor
From Melbourne, Australia
heavier, less power and more expesive than a CA18DET
sorry i could probably be more helpful, i did start a thread ages ago which listed stats on many viable engine swaps including the 4A
ill see if i can find it....
Here it is "engine comparisons"
Posted on: 2006/1/7 4:57
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisbane
hmm this is all i could find on the engine
http://www.toyota-mods.org/engines.txt
try finding a toyota forum and they should have more specifications on the 4agze
shaun
Posted on: 2006/1/7 5:00
From South East QLD
there are 4 variations of the 4agze ,, early ones had a lower comp ratio and a bigger port head with no oil squirters under the pistons ,, later engines had higher comp ratio , smaller port head and oil squirters under the pistons ,,, All had a forged and ceramic coated pistons as std ,, if the engine is not low on compression i wouldn`t bother rebuilding the engine as they are a very strong engine in std form .. they are 25kgs lighter that a CA18det ,, i have some custom madrel bent extractors to fit a 4agze into a 1200 4 sale ..
Posted on: 2006/1/7 5:56
hi how much do you want for the exstractors
mine's the one with the bigger port's
Posted on: 2006/1/9 2:38
From Tamworth, NSW
hey i thought the 4age was lighter to??????
Posted on: 2006/1/9 9:00
From Bendigo, Victoria, Australia.
datto masters are allowed to be biased when it comes to datsun/nissan things.
why anyone would want to put anything but a nissan heart in a nissan body beats me tho
Posted on: 2006/1/9 9:55
From campbelltown (sydney) australia
especially when there are bolt in conversion kits and heaps more bolt on extras for the nissan motors....
Posted on: 2006/1/9 12:40
* caution, sunglasses must be worn to view my ca18det *
