Weber 32/36 Throttle Return Spring
From Brisbane
Hey guys what did you use for a bracket to attached a secondary return spring for the throttle linkage?
I used a bracket off Mazda 1300 stock carby before but its very hard to get these carbys nowadays
just too lazy to make my own bracket....
anyone else using return spring for the linkage?
Posted on: 2006/1/8 4:25
Re: Weber 32/36 Throttle Return Spring
From Townsville
If i remeber right i used the linkage off the standard carbie, has been awhile since i done it though but it works fine, just gotta play around with it once it on to set it right.
Posted on: 2006/1/8 10:41
From Brisbane
I wasnt talking about the linkage
I know you can use the stock carby linkage
but
what I was asking is the bracket that holds the return spring that connects to the throttle linkage
Posted on: 2006/1/8 12:07
When i put a 32/36 webber on i use the bracket and spring from the standard 1200 carby hold it on by placing it under the screw that holds the top on the carby on. than just bend it up to take up the slack.
easy as!!!
simple is best!!!
Posted on: 2006/1/8 12:44
