oil filter number & firing order layout for A15
From Bunbury Western Australia
Hey all I have been searching around trying to find out what the correct oil filter is to use on my A15, I was told to use a Z145a filter but it is too big?, also what is the firing order for the engine? I am assuming the engine rotates clockwise which would also mean the distributor rotates clockwise too? and the cylinder numbers are counting from one to four firewall to grille?
Posted on: 2006/1/9 23:58
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
Re: oil filter number & firing order layout for A15
Not too shy to talk
From Christchurch NewZealand
Hi Blofy,
In regards to the oil filter i use a Z191A which is off a 4AGE toytoa motor, only because it is shorter as i have a winged sump. i think off memory the proper one to use is a Z101.
The firing order is 1,3,4,2 Number one being at the thermostat end, number four at the fire wall end.
Posted on: 2006/1/10 1:04
From Perth
hmmm...... I answered this at work but now the post is gone
So try again
I use a Z37 in the racecar
Posted on: 2006/1/10 11:07
Firing order? Hell, i'm still trying to sort out the firing order on my Victa 2 stroke.
Posted on: 2006/1/10 20:59
Love your Datsun.
Treat it well.
From Springwood NSW, Formerly Tas.
90% sure dizzy rotates anti clockwise
Posted on: 2006/1/11 1:31
1978 120y Coupe.
Firing Order: same as A12 (and nearly all four cylinders)
Rotation: Same as A12 (it is the direction the advance unit points, rule of thumb for all engines).
Oil filter: Use the same as A12. There are several Nissan part numbers for a-series engines, but they all fit on a rwd A-series engine.
Posted on: 2006/1/11 3:18
