(1) 2 3 »
A series rebuild pricing
As a simple conversion i wana drop a A15 in my 1200 ute. As this seems the least expensive excercise (for a school student) for instant power gains. My question is what a budget for a total rebuild would be if im seeking around 120hp? And what the optimum mods would be for this sort of power gain?
thanks in advance
Posted on: 2006/2/11 11:07
Re: A series rebuild pricing
From Bunbury Western Australia
wow mate your a few days too late
http://datsun1200.com/modules/newbb/v ... topic_id=20123&forum=2&10
on the other hand you could find some nice webers on ebay for about $500 and have a cam ground for $120 and perhaps find a electronic dizzy from $150-$550 the you might be able to make 120hp at the flywheel, things can get carried away when your looking for more and more power!
Posted on: 2006/2/11 12:03
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
From SE Melbourne
I'd have to agree, as I'm in the process of rebuilding an A14 to give me 80hp, without touching the bottom end of the motor.
I don't even know for sure how much I have spend so far but it must be getting close to $1000 with a bit more to go.
New gaskets, ignition parts, the tool you need each time you get stuck...
Rebuilding an engine get real expensive real fast...unless it's just me - but ask some of these guys what they have spent on their cars, and if they will tell you...be ready for a shock.
The cheapest to 'service' an A14 so it will go again at maybe 70-75hp would probably be around $400 I'd say to make sure it was reliable enough to last more that a few starts.
I continue to be suprised how much money goes into a 'budget' build.
Posted on: 2006/2/11 23:36
Mildman, Datsunless
From sydney
The most economical route would be to wait until someone is selling their hotted up motor to do a CA conversion, you will get it for about a third of the build price.
Posted on: 2006/2/11 23:42
Engine repair/ rebuild costs can range from the incredibly inexpensive, if you can do the actual work yourself, to something aproaching the utterly rediculous, like mine, & believe me, $6,000 is so very easy to spend. So very very easy.
I think that Sidedraught has the best overall plan in ther 'bang for buck' stakes
Posted on: 2006/2/12 0:11
Love your Datsun.
Treat it well.
Not too shy to talk
So what do you get for $6000 thats aproaching the utterly rediculous?
2
Posted on: 2006/2/12 0:28
I hate fagots
A beginning.
Posted on: 2006/2/12 1:08
Love your Datsun.
Treat it well.
Not too shy to talk
Whats that meant to mean?
What motor parts and work equals out to $6000 and is only a beginning.
Or do you just think the $6000 sounds impressive to say?
5
Posted on: 2006/2/12 3:14
I hate fagots
From Perth
I think I'm the only one silly enough to spend more than Dodge on an A series
I have reciepts for alot more than that (almost twice as much)
You can do it alot cheaper. It depends if you want an engine thats strong and reliable in the long run
Or you can do a basic budget rebuild and get close to the figures you want
Its up to you
Posted on: 2006/2/12 3:53
Pay attention Mummys boy
Factory EFI, used, almost complete, with computer, purchase only. $1000
New, fully featured computer [allow $1,000 to $1.500]
Factory competition alloy oil pan, purchase, import, repair, & replace missing parts, ready to install, allow $750 to $850.
Distributor About $400 [I forget exactly.]
Irridium plugs $88
A12A Rods, Purchase & import only. $200
Harmonic balancer, made to customers order, allow $400 [or more]
A14 Crank [purchase only] $75
1200GX cylinder head, fully rebuilt to my specs, but not including purchase price, freight paid both ways. $1900
Made to order adjustable cam sprocket & timing case $300+
Roller rockers, almost $800
Alloy rocker cover [if used] $300 or $350 [I forget]
To this you can add
Custom work to crank. [Additional cross drilling, knife edge, polish etc.]
pistons & rings
All gaskets & seals
New camshaft
New cam bearings
New tappets
New water pump
New oil pump
New clutch
Fully prep rods to competition standards.
Custom or modified flywheel
New or reconditioned Altenator
Powder coat all parts as required
New or reconditioned starter
Best quality ignition wires
New thermostat housing & thermostat.
Stainless steel fasteners where suitable.
ARP Head stud set.
Custom made pushrods
Best quality timing chain & crank sprocket
Fully machine & blueprint cylinder block after crack testing.
Fully balance all the usual rotating & reciprocating parts.
Buy new, then porcelain coat, 1200GX exhaust manifold.
Completely rebuild EFI.
Get YaMommy to add all that up & see if it doesn't come close, & I don't really care if you are impressed or not.
Posted on: 2006/2/12 7:06
Love your Datsun.
Treat it well.
(1) 2 3 »
