« 1 ... 3 4 5 (6) 7 8 9 ... 30 »
Re: Finally start my 1200 sedan build thread
From Narellan,Sydney
Neather is the 13b turbo Or cage goin in it but #OOPS# happens
Posted on: 2013/2/17 11:25
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
Got my dash back from my trimmer the other day and looks awesome.just got to fit the gauges and put it in the car.only a couple months to go and she'll out cruising the streets
Posted on: 2013/2/28 21:17
From Brisbane
is going to be tough car. police are going to eat you. I would be scared to drive that on the street knowing it might get impounded for months on end. good luck to you
Posted on: 2013/3/1 1:08
Won't be getting impounded.nothing they can impound it for
Posted on: 2013/3/1 2:36
From windsor, sydney
hey datrotor , cool build looks impressive , but are you really going to drive it on the road? don't want to sound like a d#*K but that cage with welded corners on the main hoop , was it worth the effort for something that wont pass any motorsport body rules ?
like I said I don't want to criticize just don't want you to be injured unnecessarily
Posted on: 2013/4/21 10:00
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
Yep street driven.and it will be fine mate its thick enough and strong enough so I have no issues.
Posted on: 2013/4/21 10:33
Not too shy to talk
From Sydney
nice work, any updates?
Posted on: 2013/4/25 11:48
Thanks just been doing a few little bits here and there.went and pick up my lsd centre and housing so spent a bit of time cleaning then up.(will put up pics Tonight) just need to modify my 4 link brackets to let my coilovers bolt to them then hopefully end of the week make it over to drop my diff to craft differentials as they will now be shortening it,fitting disk brakes and get new axles made.should all be up and rolling in a couple weeks then it goes off to finish the trim :) all is good
Posted on: 2013/4/28 4:03
Before Open in new window
After in primer Open in new window
Cleaned diff and housing up and put in primer.will be all black by the time brackets are on and has been shortened
Posted on: 2013/4/28 5:53
Just another quick shot.picking up coilovers and shock mount up this week or next a few measurements then get my shortened diff sortedOpen in new window
Posted on: 2013/5/27 10:18
