110 Wagon diff
Does anyone no if the 110 wagon diff is the same as the 110 ute/pickup with bigger axles and be able to take something
like skyline centres
Rob
Posted on: 2000/8/17 6:25
Re: 110 Wagon diff
Quite a regular
Hello
I've got a 1200 wagon diff. They have the same gear ratio as the ute diff. I have heard that bluebird 8 bolt diff centres fit ute diffs and most
likely wagon diffs.
I haven't heard about skyline centres, but if they are an 8 bolt centre they would most likely fit.
(don't take my word for it about skylines)
Posted on: 2000/8/20 8:12
Re: 110 Wagon diff
From Wellington New Zealand
B110s/ 1200s used the H145 diff, including the wagon, the ute diff is a H165 , the same as Sylvias. The Skylines use even bigger diffs, They all look similar but are different.
To fit a Bluebird diff centre you will need the ute housing.
Posted on: 2000/8/21 4:36
