blow thru or draw thru
Not too shy to talk
From Geelong
i've set up a blow through system on a L20 running twin 40DCOE webbers on it and it works really well. All you need to do is run a rising rate fuel pressure regulator and run a blow-off valve before the carbi's also you'll need to run a good fuel pump ( I run a holley Blue ) The pump has to run 4-5 psi more than the boost your running.
Posted on: 2004/6/3 10:48
Re: blow thru or draw thru
From Christchurch NZ
Try thw "REPLY" button.
For what a rising rate fuel reg and holley pump costs I could build the whole drawthrough setup.
Posted on: 2004/6/3 11:00
Forced Induction!
