what u think
o.k.
If it was a dream for me. with my 1972 datsun 620 truck. L20B. with all the modifacations that could be done to the engine, trans, everything. what do you guys think the fastest i'll clock on the quater mile. and list the things needed to do to go that fast.i'm brought up racing at "blue lights","red roads".all illegal racing in hilo, hawaii. Just curious to see what you guys think.
Posted on: 2004/10/5 20:09
Re: what u think
From Toowoomba QLD
what I think is DONT RACE ILLEGALLY!!!
Posted on: 2004/10/5 22:46
Re: what u think
From WA
i think this is the third thread for what you want done to your ute.
when you have something add about a subject you've already brought up, use the "reply" button, not the "post new thread" button.
you want to do ALL the mods to your L20 right?
what is your project budget?
how fast do you want to go?
would you prefer an NA screamer or a turbo kit?
will it be a carby or EFI?
what is your suspension like?
and the brakes?
there are a million variables, so HELP US OUT HERE and specify what you want.
Posted on: 2004/10/6 6:42
Re: what u think
Quite a regular
From Narangba, Brisbane.
pro-240c, i'm going to recondition my A15.
but also while im doing so, i want to give it some beef behind it.. make it handle the power i want to go through it...
budget ... $2,500 <-- including Reco.
I've heard about this GX head you can use?
what size cam am i looking at? do i want to flow the heads out, modify the inlet exhaust manifold ? im running a Down draft webber onto it atm, my bottom end bearing is gone on me so i need to work on that when i do the recon dont i ??
do i need stronger con rods?
I wanna rev it out, and not through pistons in the air
Posted on: 2004/10/6 7:07
Re: what u think
From WA
are you building a long motor, full reco?
are you doing it yourself or paying someone else?
if you're doing it yourself (bar the head which just isn't worth the hassle) then you may just do it on that budget.
you shouldn't need custom rods. a shotpeening and cryo treatment should be all you require if you use quality bearings.
i have held 7500rpm (under load for what seemed like a good minute) on a reco'd bottom end with the aforementioned rods, a polished and cryo treated crankshaft, ARP bolts everywhere and cryo treated mains caps. when i took the engine apart it had 12mm
Posted on: 2004/10/6 9:24
