Re: 5 speed
Not too shy to talk
From La Mesa
I am using a 5 speed from a 210 wagon in 1200 '71.
No body work has to be done and it bolts up to any A serial motor. You will have to build a rear support but
that is it.
Posted on: 2000/10/30 9:48
Re: 5 speed
From Castro Valley,CA USA
I also have a 5spd from a 210 and have used a 5spd from a B210. The only problem i have is that there is no room for the
reverse light switch.
Posted on: 2000/11/2 12:12
Re: 5 speed
From Snohomish, WA USA
I found out that if you get in there with a hack saw, you can saw off the top part of the dome that holds the threads for the tranny bracket bolts. You will then have to trim the
original tranny bracket and weld legs to the fastener holes to fasten it in. Mind you, this is only a temp fix. You should weld up some new brackets and add a few more fastening
points.
Ernie
Posted on: 2000/11/2 12:42
