GEARBOX QUESTIONS
Quite a regular
From Eaglevale NSW OZ
Ive done a couple of CA18 conversions in the last few years using front cuts. These have been for other people and every time i say that i will not attempt it again. Well this time this one is for me for our business as a delivery ute
My question is
I have on both occassions used the CA box and auto tunnel, and a commercially available fitting kit, which brings the gear lever right back. A supposedly knowledgable fellow from one of these import places said that an RB30/VL gearbox would be shorter and that the CA bellhousing would fit onto the sandwich plate of this box. So I bought a reco one and you guessed it, it does not fit.The numbers cast into this box are RP71C#1
What box will fit the CA bellhousing and be shorter and what car is this shorter box from
Thanks
PS If anyone is after a reconditioned RB30/VL five speed I have a spare one !!!!!
Posted on: 2005/4/24 3:55
Re: GEARBOX QUESTIONS
From Brisbane, Narangba
I dont know from experience but I have heard that people use the stumpy skyline box to bring the shifter forward however this box is alot weaker.
Posted on: 2005/4/24 4:23
From brisbane qld
i have a ca in my wagon and have spoken to quite a few people and there is not much that can be done unless you are willing to spend about 1500 to have a new bellhousing machined to fit some thing like a celica 5 speed. so in the mean time i just turned the shifter around and its a bit better. i got mine in without cutting the tunnel at all if that makes any difference !!!!
Posted on: 2005/4/24 14:58
From Melbourne AUS
its the MR30 skyline 5spd that makes the shifter come up throught the standard hole..
and yes it bolts up to the CA bellhousing
Posted on: 2005/4/24 15:13
1973 B110 A12
Quite a regular
MR30 would be around 1985 vintage ??? and from behind which engine ????????
Thanks
Posted on: 2005/4/24 16:04
Not too shy to talk
From Narre Warren Vic
From behind an L24 ,but it needs a ca bell/h from a s3 bluebird.I've heard these boxes are plenty strong too.Now I belive the gazelle box is the same box with and it bolts straight up to a ca (they are both fs5w71b).
Posted on: 2005/4/25 2:53
