s13 brakes onto 1200 ute help please"
Not too shy to talk
From Grafton , NSW
Hey guys My brakes are fu#k*d in my dastun 1200 ute and i have a set of 180sx s13 brakes and think about puting them on atm ok im doing some research on wat i need to do it .. will i need 180sx master cylinder.... can you guys give me so tips on wat i need and the prices to do it im new to this stuff sorry .....
cheers shauno!
Posted on: 2006/2/20 10:21
Re: s13 brakes onto 1200 ute help please"
Not too shy to talk
From Grafton , NSW
bump
Posted on: 2006/2/20 11:31
From California
pretty near impossible with stock struts/spindles, but if you can get some 280zx struts you could use z31 turbo front hubs/discs (5 bolt pattern) and then some fabbed brackets for calipers, but at that point u might as well do z32tt calipers. good luck!
Posted on: 2006/2/20 17:54
From Brisbane, Australia
Easiest way, give Kev Rowley a call and he can send you what you need.
You can use a stock Master Cylinder.
Pretty much as follows:
Take disk off the hub
Machine hub so the the S13 rotor drops over the top.
Change studs to S13 studs (longer)
Make some Dog Bones (adapters) to mount calipers.
Put her back together and you are away.
Talk to Kev. He can probably post some adapters down.
Posted on: 2006/2/20 22:26
From California
i hope you're not suggesting putting s13 brakes on 1200 spindles/hubs
but i'd like to hear more about machining involved if you were to use the zx strut
Posted on: 2006/2/21 4:37
Not too shy to talk
From Grafton , NSW
Hey mate,
can you give me this Kev Rowley lads number plz and ill go from there....
cheers shauno
Posted on: 2006/2/21 6:00
From Bris-Vegas
PM sent
Posted on: 2006/2/21 6:06
CA18DET '74 1200 ute project
From sutho shire, NSW, AUS
With kev's set up you have to use 120Y struts preferably 78' ones and there bigger and stronger!
Elliott
Posted on: 2006/2/21 7:59
From Sydney
Anyone got a ballpark figure on what Kevs kit would be worth? I'll get the calipers etc.
Could someone PM me his number?
Thanks
Posted on: 2006/2/21 9:23
From Jimboomba s/e QLD
if you have the 120y set up or the coupe set up
the whole lot was 450 or 500 i think?
cheaper if you get most of it yourself
Posted on: 2006/2/21 9:42
82 1200 ute ca18det project still building
