(1) 2 3 »
engine keeps cutting out
From Gold Coast
hey i have a A14 blow through turbo 1200 ute aka fat14s old car. any ways i'm having problems with it idleing, it wont idle at all it just cuts out, could any one give me some clues on what it may be? i've tried to find leaking vacuum leads but all seems fine.
cheers
Josh
Posted on: 2006/3/18 8:24
Re: engine keeps cutting out
From Sydney Australia
Can you keep it idoling by resting your foot on the accelerator slightly? Can you still drive it? if yes does everything feel normal?
Posted on: 2006/3/18 8:49
Currently own a 73 1200 with sr20de and a 71 1200 with almost finished a14 blow through
From Gold Coast
yeh exactly that
Posted on: 2006/3/18 9:03
From Bendigo, Victoria, Australia.
it sounds like the butterfly in the carby is shutting to much.
adjust the throttle cable so that the butterfly is more open.
TIP: make it so that it idle to fast (say 1500 revs) then drop it back from there.
i hope there is some easy way to adjust the throttle cable on the a14
Posted on: 2006/3/18 9:40
"Like a Rolling Stone"
Bob Dylan
New Daily: <<<<Now For Sale.
1972 B110, 13" Bathurst mags, airbrus
From sydney australia
are you using a standard carby?it sounds like the idle solenoid is not working.this is the hexagonal piece coming out of the side of the carby with a wire going to it.this solenoid cuts off the fuel at idle.the wires are fragile & will break off,or the wire might not have been connected.it could also be a blown fuse cutting
power to this.i've seen all three things happen,& the car just wont idle,unless you crack the throttle slightly.could be worth a look.
Posted on: 2006/3/18 9:59
From Gold Coast
yeh fuses are all right, i dunno how to adjust the cable it's alot different than what i'm used to, only got the car few days ago so dont know much about it, i'll have a look again though
Posted on: 2006/3/18 10:12
From Gold Coast
ok i put the idle up but still cuts out It has a VL electric fuel pump, i've heard that they may be the problem as that's what happened to a mates rodeo
Posted on: 2006/3/18 13:09
What carb are you using? The fuel pump wont be the problem if its supplying enough fuel during boost i think and you say it drives as normal.
I was having similar problems just befor my turbo broke so I pulled off the carb (webber 32/36) and rebuilt it with a kit from RIPCO (repco) for $50 or something when it all went back on it didnt fix the problem I wanted it to but it fixed the idol.
Also noticed there was a fair bit of carbon build up on the primary side of the carb maybe this crap blocks off the idol passages and just needs some regular attention.
I also fitted a stoichiometer more for making sure i dont lean out on boost but comes in really handy for tuning your carb.
Posted on: 2006/3/18 14:31
From Gold Coast
says 32/34 on the side, i've taken it off, dont really know what i'm looking at, neva had a carby car before. now what do i do? :S
[img=http://img67.imageshack.us/img67/4051/picture11556ma.th.jpg] carby closed
[img=http://img80.imageshack.us/img80/2900/picture11546is.th.jpg] carby open
Posted on: 2006/3/19 1:24
Can you take a photo of the top or does it look like this? Yours looks to be pretty clean
Thats what mine looked like befor I cleaned it.
Posted on: 2006/3/19 1:55
(1) 2 3 »
