cam angle sensor and TPS wiring - which wires are signal?
It's a hitachi cas on a redtop
has a small (like 20 gauge) black wire
black/white 18 gauge
black 18 gauge
white 18 gauge
also the throttle position sensor
Green/orange wire
kight green wire
red (with pink band- signal wire?)
I am wiring these to an autronic SMC and it is calling for
trigger supply
reference trigger i/p
cylinder pulse trigger i/p
throttle position supply
throttle position input
Posted on: 2006/5/2 0:50
Re: cam angle sensor and TPS wiring - which wires are signal?
From Burbank, CA
TPS's are generally a potentiometer so the left wire is +5 the center is signal and the right is earth
Posted on: 2006/5/14 22:56
|||\ 81 KPB310 /|||
