surge tank setup
From campbelltown (sydney) australia
hey guys just wondering how people go about the lines for their surge tanks in ute, they have the stock line for the one to the reg and the vapour line which im going to use as return from the reg, but u need another line for the surge tank overflow back to the tank dont you? or can u just let the surge tank get full and sort it self out? and are you able to mount everything on the back wall of the inside of thetray, will i have any problems with gravity feeds or returns or wateva?
Posted on: 2006/7/23 10:38
* caution, sunglasses must be worn to view my ca18det *
Re: surge tank setup
From Flinders View, QLD
I am planing to run a Fuel tank from a R31 skyline, Little bit of fabrication and some new larger fuel line and wallah. The surge tank is inside the fuel tank and I also increase my fuel capacity to 65L. I dont think there is any problem with having everything in the tray of the ute except for the fact that it will be easy for someone to knockoff. As for your your fuel line set up go to a few of the web sites that deal with EFI and electric fuel pumps and check out the Diagrams they have.
Posted on: 2006/7/23 12:06
