fule tank for ca18 ??
From perth airport
hey all , im unshore if i have to change my fule tank will the stanand datto 1200 tank work with a ca18de ?????
Posted on: 2007/2/10 14:29
Re: fule tank for ca18 ??
Because the CA is fuel injected it will require a return line plumbed back to the tank. Whilst it's not to difficult to modify the original tank for the return line, you will also need to pump the fuel at a much higher pressure...therefore you need to invest in an EFI fuel pump and a surge tank. The other option that a lot of us 1200 ute guys do is to fit an R31 Skyline tank up under the tray where the spare wheel normally sits.
This tank has an inbuilt EFI pump and internal baffles and means you are running a factory approved fuel container. However bear in mind that you need to weld on some RHS beams to bolt the tank to and get a new filler neck pipe to connect it up..so still a bit of mucking around. It does look a bit like a drop tank at the rear too, which you may or may not like.
Posted on: 2007/2/10 14:43
From perth airport
thanks dude i have a silvia tank i was gonna mount it in the tray as i have a hard top cover on the ute . so it wont bee seen should work ?
Posted on: 2007/2/10 14:50
From Brisbane
If your goin to put a fuel tank in the tray why don't you get an alloy tank made up, might cost a bit though. But you can pick an r31 tank up for $50 from a wrecker. Weld in two lengths of rhs underneath and bolt tank to it. Not that costly if you were concerned with keeping the price down. I don't think i'm a fan of puttin silvia tank in tray. It will work if you connect lines up correctly. It's up to you. Good luck
Posted on: 2007/2/10 23:56
From perth airport
i want a alloy droptank later just trying to use all the stuff i have at the moment as later i will need a bigger diff then wonce thats in build a droptank around it .
Posted on: 2007/2/11 10:06
From Adelaide, SA the drift state
i am going to use the original tank until i save up for a drop tank.
Posted on: 2007/2/11 20:52
From Ipswich
Hey there
Im making up a drop tank this week for mitch at the coldcoast. Ive custom made it to do into a sunny sedan. Its a ally droptank that fits up under the boot. Hopfully it should be finished this week and ill put some pics up
Trent
Posted on: 2007/2/11 21:01
