« 1 (2)
Re: ca18det prices?
From perth airport
in perth wa ther $2000 for half cut or $1200 for motor and box wit no loom or ecu
Posted on: 2007/8/2 3:57
perth airport parking
Datsun 1200 ute A14
Re: ca18det prices?
From Far, far away
The half-cut is worth more because it is tested before the cut, so it's a known runner. Front-cut not so.
Posted on: 2007/8/2 3:58
Re: ca18det prices?
I was talkin to a bloke at RX engineering he was sayin the stock computer in them a really sensitive, he said as soon as u put an ehaust upgrade on or induction work the motor tends to play up with wrong fuel air ratio etc etc? he said id have to go with an after market computer such as a microtech is this just sales man talk?
Posted on: 2007/8/2 4:01
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
Re: ca18det prices?
From perth airport
sounds like hes trying to get a extra 2 grand out of ya
Posted on: 2007/8/2 4:08
Datsun 1200 ute A14
Re: ca18det prices?
From Far, far away
If you wanna make serious upgrades though an aftermarket ECU is a wise choice anyways. And there's no better time to upgrade the motor then when it's out of the car.
Posted on: 2007/8/2 4:17
Re: ca18det prices?
From Sunnybank, Brisbane
damn right Whorida, when the motor is out do as much as you can. nuthin wrong with using the stock computer on a basically stock motor though. if you keep stock turbo you'll be fine.
Posted on: 2007/8/3 23:30
Re: ca18det prices?
From brisbane, qld
I say if you can get a complete running front cut for under 2500 grab it.
The price of ca manual front cuts keep going up and up because of the rarity and demand for them. The silvia guys eat them up at a rapid rate.
If you can get them for 2000 or less id be grabbing a couple, cause it wont stay that way for long.
Definately get a front cut for the conversion, life will be a lot less complicated and it will save a lot of running around finding missing bits.
The stock computer will be fine with exhaust, intake, and turbo upgrades, just dont go getting a huge turbo. A t 28 would be no problem. You can squeeze about 12 or 13 psi out of a stock turbo. Add an intercooler and a decent filter and you will have a good supply of horse power for a while.
Wait for stage two to get the programable ecu and bigger turbo ect.
Posted on: 2007/8/4 1:57
« 1 (2)
