ELECTRICAL GREMLINS
From Launceston, Tasmania
Hi all, I am experienceing some problems with my electrics.
First of all, my low beam headlights aren't working but my high beams are.
Secondly my wipers when turning off, they wont stop at the bottom of the windscreen just any old where.
I have swapped over the indicator stalk but that didn't fix it no fuses are blown either.
This has all only happened recently, just would like any feedback if anyone has had similar problems.
My dad suggested there could be a dry joint somewhere.
Any ideas guys?????
Posted on: 2007/8/27 11:16
Re: ELECTRICAL GREMLINS
From Portugal
I had the same problem with the low beam headlight, turned out it was lack of ground (negative) because my wires where all dry...take a look around the wires, see what you find...about the wipers...i have no idea...hehe...sorry...good luck...
Posted on: 2007/8/27 11:33
Datsun 310GX(FWD) and 120Y(RWD)...drive straight or drive sideways...
From Brisvegas, oz
with the wiper have you tried tightening the swively bit......trying to think what its called... i had the same prob it fixed it
just go through and check all the nuts and bolts
Posted on: 2007/8/27 11:34
www.camerasplus.com.au
From Sydney
from memory there some electronic component that stops the wipers at the bottom ill have a brouse through my tech notes to see if i can find it.
Posted on: 2007/8/27 11:40
From Perth WA
Yeh its in the motor i think. So new motor if it annoys you.
Posted on: 2007/8/27 11:55
Chris...
From Brisvegas, oz
yeah the way they work is as the wiper spins it slides over a contact and this is how it knows where to stop (it looks like a disc inside the motor) i still think you should check all the bolts first.
Posted on: 2007/8/27 11:56
From Perth WA
or u could just switch them off just as they get to the right spot nah fix it properly.
what is dry wires?
Posted on: 2007/8/28 6:29
