Ive decided to put my ute up for sale guys. Ill appologise now for the lengthy post!! Bellow are some pics and info about the car. Im selling it as-is. No reg or rwc. Keep in mind, this is a project! The car is not finished!! List of mods include :-
VS Commodore diff, shortened (obviously) New LSD, New 4.11 gears. 28 spline axles.
Stanza Front end, Lowered King springs, New Monroe inserts. New ball joints, tie rod ends. Also has a "Boof-bar" (Strut Brace) fitted.
28mm Whiteline Swaybar.
All bushes are nolothane front and rear
VT Commodore 300mm disc (slotted) with AU series 3 Twin piston caliper on the front. Standard VS Commodore disc and caliper on the rear. (Supply and fitted by Hoppers Stoppers), New booster and Master cylinder, all new brake lines. Front lines are also braided. Custom Hand brake cable made.
Entire Floor/firewall has been sound-deadened with stinger roadkill matting.
New grey carpet fitted.
Black Racing bucket Seats fitted
Custom Autometer dash. All carbon fibre series gauges. (not wired up at the moment, senders are fitted however) 3.3/8 Tach and Spedo (kmh) 2.1/16 Oil Press, Water Temp, Volts, Fuel Level. All gauges are electronic. Push button start, also located in dash. Dash has also been re skinned by the dashboard doctor in dark grey.
Fuel tank has been removed, as there is a 60 lt RCI fuel cell in the tray.
Also had wheels made up (interceptors) they are 15x4 on the front, fitted with new Brigdestone potenza's. 145/55/15. and 15x6 on the rear, fitted with Toyo's. 195/55/15. Wheels were powdercoated silver, with a clear over the top.
Exterior wise, Its painted the Ford BA orange. Talgate latches, bumperettes have been removed. Also has GTS Monaro mirrors.
As for the motor, its obviously set up for a ca or something big. The a12 is still in there, with the standard 4 speed box. The tall shaft did get the "cut and shut" as they call it. Engine was rumored to have work done to it. Stock carby fitted, JTS extractors have been heat wrapped.
The pics are below, guys pm me if you want more details. All offers will be considered guys!! thanks - DoM
