Advice on A15 Please?
Quite a regular
From South-Africa Pretoria
Hi,I have a A15 in my Datsun. I want to put a R65 Cam in it. I think of putting up twinn 40 webers,what do you guys recommend the jet size on the carbs should be? I have a 5speed box,1200 ute diff. Electronic dizzy, ported head,double valve springs. Any help please? Thanx CCG.
Posted on: 2008/2/2 9:13
Re: Advice on A15 Please?
From Perth WA AUS
I recommend that the first thing you do is sell me your 5spd gearbox, then maybe I talk!
Posted on: 2008/2/2 11:35
From Christchurch NZ
There is probably a computer program that you can enter your engine displacement, head flow figures cam lift and duration etc, and It can then calculate (Within a bull's roar) what your jets should be. Failing that, stick it all together and stick a wideband A/F meter on it and jet accordingly.
A webber/delorto guru may be able to make an educated guess at a good baseline jetting.
Posted on: 2008/2/2 20:55
Forced Induction!
