lowering
From adelaide hills
how can i lower my ute (legally)?
what do i have 2 buy?
can i do it at home?
IT IS WAY 2 HIGH
Thanks!
Posted on: 2008/2/3 9:16
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: lowering
From Newcastle
take ur leaf springs out and take them to a spring place and have them reset . . .i had mine lowered 3.5 inch i think cant member
Posted on: 2008/2/3 9:22
Re: lowering
From adelaide hills
wat about the front though
Posted on: 2008/2/3 9:25
Re: lowering
From sydney,Australia
either cut the springs dodgy but effective or buy some lowered ones
Posted on: 2008/2/3 9:55
Re: lowering
From Christchurch NZ
A spring maker can reset your front coils as well as you your rear leaves. you will need to have you front shocks shortened to keep your coils captive. OR, if you still have original oil filed front shocks, you can slip a peice of pipe over the piston to limit full droop travel when to the car is jacked up. So hence keeping your springs captive.
Posted on: 2008/2/3 9:57
Forced Induction!
Re: lowering
From adelaide hills
both your ideas will be kept (apart from cutting the springs) neway thats later on down the track
Posted on: 2008/2/3 9:59
