GX Head Manifold Gasket
Hello
Does anyone know where I can get a GX head manifold gasket from in Adelaide?
Cheers
Posted on: 2008/5/26 13:26
Re: GX Head Manifold Gasket
From Freo
PM'd...
Posted on: 2008/5/26 13:32
A15 PSI Project Motor
'72 CB750k,
From Adelaide, Australia
Just get an A14 ACL gasket from sprints, does the job with a bit of a file, the oval ports between the A14 and GX heads only differs by a couple mm.
Posted on: 2008/5/26 13:34
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Thanks for that
Posted on: 2008/5/26 13:50
From Melbourne vic
try a nissan dealer? # 14035-H2300
Posted on: 2008/5/26 14:25
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From Las Vegas USA
Just to back up what white sedan said; I always keep an A14 manifold gasket around as a back then if need be I use a dremel tool and carve out the the needed bit to fit. Not pretty bit it works.
Tom
Posted on: 2008/5/26 19:21
