distributor vacuum line?
From adelaide hills
hi all
my a12 had valve saver fluid connected to the carby and i found out that it replaced the dizzy vacuum line for the advanced spark. do i really need the valve saver fluid???
Posted on: 2008/7/3 11:10
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
Re: distributor vacuum line?
From Toowoomba, Qld
You can always add it manually each time you fill up, thats all I've ever done. I like to run it, I've seen the results of with and without on A series engines, and it does save the valves.
Alternatively, you could 'T' the vacuum line.
Posted on: 2008/7/3 11:48
From Perth WA
No valve saver is a load of bollocks on a alloy head'd car like a A series. Its only "needed" on old cast heads. So just unplug the valve saver, thow it in the bin and put the vac line back on your dizzy. Should run better too.
Posted on: 2008/7/3 13:34
Chris...
From adelaide hills
runs heaps better now.
when i give it a boot full it dosnt cough and splutter anymore.
now i just needs some new spark plugs!!
Posted on: 2008/7/4 10:21
Quite a regular
thats because without the vacume advance connected the spark will remain the same whenn you give it a gut full making it cough and splutter
i would recomend running flash lube tho
cheers
Posted on: 2008/7/4 10:27
From adelaide hills
if i do what pendles said ant 't' the vacuum line the flash lube stuff would harm the dizzy in ne way would it?
Posted on: 2008/7/4 10:35
