120y engine into 1200
From Palmerston North , NZ
just want to no wat is required to fit 120y engine ( its got the dissy in a different place to 1200 - is this a 120y block??? ) i dont want to have to buy oversized pistons to use my original 1200 block if i can get away with it
Posted on: 2008/7/18 23:44
Re: 120y engine into 1200
From Adelaide, Australia
U SHOULD SEARCH IT FIRST BUT I THINK ITS JUST SMALL PLATES WITH 2 HOLES DRILLED IN IT BECAUSE THE MOUNTS ARE ABOUT AN INCH OR 2 APART. SOMEONE HERE MAY HAVE SOME TO SELL BUT U CAN MAKE THEM FOR ABOUT $5. ALSO THE WIRING ON THE ALTERNATOR IS ON THE OTHER SIDE SO U HAVE TO MAKE AN EXTENSION LEAD OF SOMESORT (if u know what i mean)
Posted on: 2008/7/18 23:52
thanks m8 , im only new to this ,wat do ua meen by searching it , how do i do that?
Posted on: 2008/7/19 0:14
swt , i just worked it out then.makes it a lot easyer
Posted on: 2008/7/19 0:18
From San Diego California
I did it--for a while I was running an a-15 in
mine. it worked ok with the wires for the
alternator lengthened and metal plates on
the motor mounts.. the a-12 with j-13
flat-top pistons seemed to make more power
than the stock a-15
Posted on: 2008/7/19 9:12
Wubbits
Lexus Master Tech
73 1200 coupe(ca18det no longer in progress)
1UZ now in progress
04 GX370 (new off road toy)
05 ls430
06 F250 diesel
good to see your a master tech, ive been working at my local toyota dealership for about 13 years , still cant bring myself to build a corolla -
Posted on: 2008/7/21 23:09
I've been here at the Lexus dealer since
1990 . I 've had my 1200 since 1982
so I am still more Datsun than Toyota
still I considered putting the 4.0 v8 in
mine. I am now 3 years into the switchover
to a CA18det. It seems the time I need to
put into this project just isn't there.
gotta do it soon cause the F350 costs a
whole lot more to operate than the datto
will when it's done.
Posted on: 2008/7/23 4:22
Wubbits
Lexus Master Tech
1UZ now in progress
05 ls430
06 F250 diesel
I modified my crossmember rather than make the plates for the engine mounts. The mechanic wouldn't pass the adapter plate style engine mounts for a roadworthy cert. so I just modified the mounts on the crossmember to look factory and meet and original 120y mounts.
Posted on: 2008/7/23 8:29
