Injection that noone has tried.
From Perth
I have been experimenting with fuel injection from a superbike to a A14. Good news guys.....this weekend I had it running. Got sum pics up to show it on/off the car.
We had it idling but couldnt drive it because the fuel pump was an internal pump and couldnt be mounted externally.
Have ordered new pump from www.tweakit.net hopefully be here before the cruze this weekend!!!
Posted on: 2008/8/19 13:40
Re: Injection that noone has tried.
From Geelong, Vic
what computers it running? looks like your using the bike injectors and fuel rail too
is the engine stock other than the injection?
going to try to do the same thing with a set of GSXR 600 quads on my L series probably running a haltech E6X if i can find a cheapish one second hand
wouldnt say its injection no ones tried, it gets done all the time on hondas in the US and ive seen a few setups on the BMSC rally forum. but still good work getting it going
be interesting to see how it runs once its got enough fuel going to it
Posted on: 2008/8/19 13:53
From Perth
have tried finding any info i can on motorbike setups to cars. all that I could find is that honda one and he didnt even use the injectors off the bike....just the bodies. I am using a haltech f7 computer (fuel only). picked it up real cheap.
btw guys youtube clip is up....sorry for crude video doesnt matter that you pay $1000 for a smartphone cameras still $hit.
http://www.youtube.com/watch?v=aFUeFk5DKJs
Posted on: 2008/8/19 13:59
From Armidale N.S.W
Says video cant be viewed
Posted on: 2008/8/19 14:05
73 1200 wagon SOLD
From Perth
Its working now.....sorry just uploaded it.....yes...that is my cheesy laff at the end lol
Posted on: 2008/8/19 14:06
From Geelong, Vic
honda setup
they didnt use the bike injectors as they werent big enough
how have you gone about setting up the tune for it, did you use a map sensor or did you tune it to throttle position Vs RPM?
also how big are the r6 throttle bodies?
Posted on: 2008/8/19 14:20
From Perth
a combination with the f7 it has a map sensor running a vaccume pipe to the comp. also a TPS, and a ignition pickup. it also has air temp sensors and coolant temp sensors.
I didnt have it running for long. but i will find out this weekend how the bike injectors go. the specs of the bike say the setup is good for 130hp+ @16000rpm.....who knows how they will go on the car.
ID of the inlet is about 38mm
lol couldnt imagine how much horses they trying to get out of the VTEC. more than some bike injectors will supply.....i would like to get 130HP from the A14.....but doubt it
Posted on: 2008/8/19 14:29
From Geelong, Vic
is that 38mm at the butterfly? if so im thinking thats a tad big for anything less than a full on race spec A series
its like having 45mm webbers with 38m chokes
said in the link that the injectors had a pretty poor flow rating, im assuming they were comparing to stock VTEC injectors
Posted on: 2008/8/19 14:42
From Perth
Dunno too much about them dude. im pretty sure theyre 38 at the butterfly......im just gunna bolt it up this weekend and c how it goes....
all I can say at the moment is that it runs and Idles we will see how it drives on the weekend.....time will tell
wish me luck!!
Posted on: 2008/8/19 14:53
From Geelong, Vic
mmm thinking, probably wouldnt have to be a race spec engine. but would want a decent cam and a bit of porting to make use of them
good luck
Posted on: 2008/8/19 15:12
