What oils and coolants do we use in our dattos?
From Adelaide, SA
After finding out my alloy radiator is completly f*&ked because i was using tectaloy 90 thinking it was a good coolant but obviously not, i thought i would post to see what others use. i am running a ca but it could prob benifit anybody thinking about doing a service and not sure what kind of stuff to use. Im about to change all the lube in my car gbox, diff, motor and coolant and the guy behind the counter at repco doesnt usually know what he talking about so i thought id ask those who do. cheers
Posted on: 2008/11/1 0:17
Re: What oils and coolants do we use in our dattos?
From Rosewood, QLD
i use shell helix ultra cus it has the ferrari symbol on it
and plain old water in my radiator
Posted on: 2008/11/1 6:18
1971 B110 sedan project.
2012 Nissan Micra daily.
From gold coast aus
i use hpr 30 penrite in z18 is a good oil for the ca maybe hpr 10 or 15 they have a book with the recommended oil for your car try autobarn the books are hanging with the oils
Posted on: 2008/11/1 7:29
From Adelaide
COOLANT - Nissan Long Life Coolant [LLC]
OIL - Nissan 7.5W - 30 SL
Made for the cars and quite economical
Posted on: 2008/11/1 9:52
Nissanman - just trying to help...
From Perth WA
Oil- Valvoline 10-40 coz its in the drum at work and i can steal it for free!
Coolant- Toyota Genuine. Best stuff there is!
Posted on: 2008/11/1 12:36
Chris...
From Albuquerque NM, USA
engine oil: Castrol 20w50
coolant: Nissan long life coolant and Distilled water...50/50/mix. In this area we use distilled water because we have very hard water that leaves deposits.
Note: just cause I posted this, it dosen't mean I know what I'm talking about
Posted on: 2008/11/1 16:46
For street use, I recommend "regular" oil and lubricants. For the CA18, check the owner's manual. It probably takes 10W40 oil.
For the gearbox and diff, 90W should work, again check the owner's manual. For the Datsun 1200, Nissan recommended (in 1972) to use 75W to 140W, so today's common 75W-140 should be perfect.
I buy whatever brand is on sale and meets Nissan's recommendations. I've never had an engine break, over 26 years of driving and many vehicles brands.
For the Datsun 1200 stock engine, transmission and diff, Nissan recommended many lubricant brands by name, and those same types are still commonly used 35 years later (example: 10W40).
Nissan Recommend Lubricants
For the radiator use distilled water in a 50/50 mix of coolant/antifreeze. If you live in freezing areas, check the coolant container for instructions (may require a 30/70 mix in very cold areas).
More details: Coolant
Posted on: 2008/11/1 22:08
From brisbane
I use Castrol R 15W40 engine oil, Penrite diff and gearbox oils and Nulon long life coolant.
Matty
Posted on: 2008/11/1 22:48
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
From bathurst nsw
for the coolant use where the system has alloy components, nulon red long life because it has the correct corrosion inhibitors for the different alloys in your system, toyota genuine is also very good, and at work we use valvoline g05 coolant because it is adaptable to all kinds of metals, so that means we can put it in any car and it meets its requirements but its more expensive.
for engine oils, sae ratings eg 10w 40 are a general thickness guide, the real thing that you should be looking at is the api rating eg sm, sl, sg for your engine. this is based on the oils wear properties and what conditions its used for. as different oils "should" be used for different seasons they change the sae ratings to suit those seasons. hense the different thicknesses of oils.
eg if your ca required a 20w 50 oil if you were to put castol gtx in your ca, it wouldnt be a good oil for it because it isnt up to the standard it was designed for, as it has an older rating eg api: sl. but the castrol gtx2 is still a 20w 50 but has a current rating oil(its exactly the same api rating as castrol magnatec.) so would be suitable for your engine eg api: sm. the higher the letter the better an oil is, as a general rule
hope ive helped you and havent confused you!!!
cheers kurt
Posted on: 2008/11/2 1:18
My car gets me from A to B...Just faster ;)
From Melbourne Vic
sr20det - running in i used the the nissan 7.5w 30 but once that was done full synthetic mobil 1 10w 30.
coolant you need to find something with a high glycol content for alloy. i use castrol anti freeze anti boil concentrate stuff which comes in a white 2.5lt bottle and costs about $30 i think - good stuff
Posted on: 2008/11/2 1:48
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
