quad throttles help
From Perth
Hey guys,
I need some major help setting up my A14 quad throttlebodies. I cant seem to tune them because my haltech reports 0kpa at 20% throttle. Can anyone help me out??? I have heard that one can put in a resivoir to store vacuum. However, when I do it just coughs and splutters, also is very laggy.
-Liam
Posted on: 2009/3/31 11:18
Re: quad throttles help
From Geelong, Vic
you will probably have better results tuning by throttle position Vs RPM
but it is correct, you will loose pretty much all the vaccum just off idle
Posted on: 2009/4/2 9:47
From Southern Highlands, NSW, Australia
Yeah you will get a better result using tps as your load sensing input. If you have to run a MAP sensor you'll probably have to build some sort of vaccum manifold with vacuum lines going to each intake runner. You'll have to fiddle with your throttle pump map to stop the lagginess.
Posted on: 2009/4/2 10:00
'72 1200 sedan hillclimb/supersprint car
From perth
plenum?
Posted on: 2009/4/2 12:38
bike TBs should have a TPS anyway....it's what they use.
Posted on: 2009/4/3 8:40
From Geelong, Vic
bike throttle bodies also have a vaccum port in each runner that would work nice for MAP sensing
Posted on: 2009/4/3 9:13
