From hobart,tas,australia
the guy to speak to is the guy from revolution racegear (argile st), he inspects race cars for events like targa and all the main rallys, so aswell as dealing in rollcages he tells you exactly what you need. ... Another piece of advice is that you may have exhaust shops or friends who say that they can just whip one up on the cheap. DONT LISTEN TO THEM... bars must be desighned properly ,bent properly and made from the right materials or it will fold in on you when you need it most. ps. mine was a prick to get in, you will need to leave your interia out, and yes it is good to put it in before painting because its very likely that you will scratch & get welding gunk on your paint + if you do get it painted after you can get the cage done at the same time,,,,,which reminds me.. for any one out there who wonder how people build show cars with out scratching the paint when installing everything is because they always atleast trial fit every thing and with engines run them in first to get all the little problems sorted out first,,,just a tip, KEEP IT ON ALEAST ONE WHEEL AROUND CORNERS AGR012 hahahaaaaaaaaaaa
Posted on: 2001/9/1 7:28
