(1) 2 3 4 »
leaf springs
From cold toast
i just grinded the head off the bolt that holds the springs together. was this a bad idea?
there is still a bolt in there but is got a slither of a head cus i grinded that part off
Posted on: 2009/7/18 7:13
Re: leaf springs
From Vancouver, Wa
The head on a standard bolt will not be round like a centerbolt will be, normally a slight bit shorter too. Just use one out of another spring pack, if you have available, most centerbolts are only grade 2 material.
Posted on: 2009/7/18 7:18
1969 Datsun 1000 (B10)
1972 Datsun 1200 coupe (ADVAN)
1981 Datsun 210(B310) 4-door (sr20det)
1971 Datsun 1200 (sedan)
Re: leaf springs
From cold toast
sorry im not following?
Posted on: 2009/7/18 7:25
Re: leaf springs
From Vancouver, Wa
Did you grind the nut off or the cylinder shaped side of the bolt?
Posted on: 2009/7/18 7:38
Re: leaf springs
From cold toast
um
i grinded off the top of the bolt
Posted on: 2009/7/18 7:42
Re: leaf springs
From cold toast
oh oh i get it, um i cut it off so i could get the lowering blocks to line up, so i dont really want to put another one in, i need it to be out really
Posted on: 2009/7/18 7:43
Re: leaf springs
From Vancouver, Wa
is it bolt that is in the center of the spring pack or a rivet that is holding clip on towards the ends of the spring?
Posted on: 2009/7/18 7:46
Re: leaf springs
From Vancouver, Wa
You need a centerbolt, other wise it won't stay centered to the axle, your block should have a nub on one side and a dimple on the other for proper installation. centerbolt should fit inside the dimple side of the block.
Posted on: 2009/7/18 7:51
Re: leaf springs
From cold toast
yeah the dimple is to far forward. could i drill holes either side of the blocks and put bolts there, so it wont go forward, and wont go backwards??
Posted on: 2009/7/18 9:37
Re: leaf springs
From northern 'burbs adelaide
the hole in the blocks should line up with the pin ... this lines up the diff under the car
Posted on: 2009/7/18 10:13
(1) 2 3 4 »
