Jetting a Weber for a A12 motor.
anybody know what is the proper jetting for a weber on a A12 datsun 1200 motor? any info much appreciated. Thanks
Posted on: 2009/10/13 0:09
Re: Jetting a Weber for a A12 motor.
From south coast nsw
what type of weber?
Posted on: 2009/10/13 0:54
And just as important, which chokes (venturis) does it have? A weber DCOE 40 with 27mm chokes will require different jetting than weber DCOE 40 with 32mm chokes.
Baseline jetting
Conversion equipment jet setting Datsun B110 (A12) - single 40 DCOE 2
Choke size 27
Aux. venturi 4-5
Main jet 1-10
Emulsion tube F7
Air corrector jet 1-65
Idle jet 0-50 F9
Accel. pump jet 0-50
Accel. pump inlet valve with ex. orifice 0-50
Needle valve 2-00
Posted on: 2009/10/13 2:55
i need to find the same info for a 32/36 for stock a12
Posted on: 2009/10/13 12:18
Car free
Weber DGV Tuning has three sample jetting specifications. Unfortunately two are missing the venturi size.
Posted on: 2009/10/13 17:03
