wtb Convo pros to suit 1200
From mandurah
hey i need to know if i can get a set of convo pros to suit a 1200 in 15s !!
Posted on: 2009/12/14 4:39
Re: wtb Convo pros to suit 1200
From SA
truth is, id love a set too haha.
iv been looking for about 2 years, checking trading post and ebay fortnightly...
i have seen one set, they were 15x4 front and 15x4.5 rear. way to skinny, they were all front rims that he purchased from Centerline. and ended up selling for about $2200.
i no that Centerline will custom order for you, just look on the website, andy size stud pattern or width.
anout $700 a rim i think?
cheers
Dan
Posted on: 2009/12/14 4:54
full resto: 1971 ute check it out in projects
full resto: SR20 1973 coupe check it out in projects
Go Hard Or Go Home
From Melbourne ( West )
Usually people convert to 5 stud, be it Holden or Ford.
mainly due to their popularity.
If you converted a Borg warner diff, you cound retain the 5 stud pattern.
A strut / brake upgrade will have the front sorted.
Then once you know what size your after, keep your eye's on ebay etc.
Posted on: 2009/12/14 5:29
'78 Ute CA18det Project
No matter where you go... There you are
From mandurah
hey good news i found a set of 15x4.5 and 15x8 in datsun stud pattern 114.3 pcd but they are 500 each
Posted on: 2009/12/14 13:02
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Melbourne AUS
vpw do convo pros, not sure if you'll get the offset you need but worth a look if your keen.
vpw.com.au
Posted on: 2009/12/14 20:46
1973 B110 A12
From brisbane. waking up the neighbours with the brap
i want them for my 1200. they look unreal on the car
Posted on: 2009/12/15 1:32
13b turbo datsun 1200 ute. (WARZ ON)
www.maddat.com.au
