Browsing this Thread:
1 Anonymous Users
(fuel line) i need help please |
the fuel line coming from the bottom of the gas tank is clogged. does anyone know how to fix it or replace the whole line?
Posted on: 2010/5/13 4:21
Re: (fuel line) i need help please |
replace it if its the rubber hose, or is it the metal one?
Posted on: 2010/5/13 4:30
metal
Posted on: 2010/5/13 5:17
From Sydney
Go to a hose specialist like pirtek (not sure if its spelt right) they can supply tube and flare it aswell, you will just need to bend into shape.
Posted on: 2010/5/13 14:55
well, i dont have much money (like 20 bucks) and i live in Canada, so is it possibly to replace it with a rubber hose?
Posted on: 2010/5/13 14:58
73' 2-door sedan
From Sydney
Yeah i guess you can replace it with rubber if you dont have too much money to spend. Pirtek is out of the question for you.
Posted on: 2010/5/14 14:15
You could use some high-tensile fencing wire and poke through the pipe... Use an air compressor also to help blow the #OOPS# out. Then flush it all out with sum fresh fuel followed by another blow out with compressed air and it should all be good! :D
Posted on: 2010/5/14 22:59
