car wont fire - help!
From Sunshine Coast, Queensland
i changed the distributor cap on the sedan yesterday but when i replaced the leads i must have accidently put them on wrong! the car started but rough so i knew something was wrong. i checked them and changed to what i was sure was right but apparently it wasn't. the motor turned over, the carby backfired but it didnt start.
i have thouroughly looked at the correct firing order and i am sure i have it right now but the car wont start the left side of the carby just keeps puffing and spluttering.
its a weber carb and i have now put the old cap back on but it still wont go!! help please!!
Posted on: 2011/1/24 23:26
75 datto ute - now selling
73 datto sedan - now building
simmos NEW ute build
Re: car wont fire - help!
From sydney.nsw
it sounds like the leads are not correctly fitted. the firing order is 1432. did you have dizy out.put engine on tdc no1 compression(turning engine clockwise), then check where rotor faces to cap position,fit leads from this point dizy turns (anti clockwise)no1 first then 3 / 4 / 2. hope this helps. cheers
Posted on: 2011/1/24 23:45
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
Sometimes I throw matches at my ute and it still wont fire anyone know how to fix this?
Posted on: 2011/1/25 0:18
Yeah dude I'm with BigE sounds like you may have muddled the leads, just make sure their firing order corresponds with the rotational direction of the rotor, sometime this can be muddled.
Posted on: 2011/1/25 1:28
cheers guys the leads are in the right sequence but i fitted them as per a diagram on ozdat that i found. Maybe the distributor isnt in the same position as factory. Will try get tdc on no. 1 and go from there. Its L16 but most 4 cyl should be the same. Thanks for the help!
Posted on: 2011/1/25 6:06
From Perth WA AUS
EDIT: The dizzy must be 180 degrees out, you can compensate for this by changing the leads around .
so when you put the leads back in the correct order it wont run?
Sorry I was a bit drunk when I wrote the original reply, Bakat says it better in his reply.
Posted on: 2011/1/25 10:28
Edited by levey on 2011/1/26 13:48:49
Datsun 1200 2Dr sedan.
so i got the order right and i found top dead centre on the motor but it still wont fire? still getting backfires...i am trying to find stuff on wiki but struggleing if someone sould point me in the right direction that would be great! thanks for your help so far
Posted on: 2011/1/26 7:00
From Bendigo, Victoria
Take your dissy cap off and turn the engine over and see which direction your rotor button is going and that is the direction you put your leads. Find top dead center on your timing mark on your front crank pulley and that should be no 1. An old habit of mine is to take no 1 plug out and put a long thin piece of wire (thin welding wire) down the cylinder to make sure piston is on TDC. If it is, put your leads in the cap in the correct firing order and to the correct plugs. If it is a points dissy make sure your points have the correct gap and it should go. You can set your timing to ? BTDC afterwards.
Hope this makes sense.
Posted on: 2011/1/26 7:38
From Malaysia
i think your dizzy is 180 degree out of phase. try swap your lead 1 and 4, 3 and 2. sometimes the mechanic put the dizzy 180 degree out of order, but no problem, swapping 1 and 4, 3 and 2 will solve it.
Posted on: 2011/1/26 8:45
i will try that in the morn. thanks a bunch!
Posted on: 2011/1/26 12:04
