What coil with pertronix
From Sydney
Hi i have installed my pertronix kit with the supplied coil.
What i want to do is tidy things up so wondering can i run a small gt40t coil?
I just want to boot the ballast resistor, basicaly.
Thanks
Oh and i did search this topic for a while but sometimes you come out more confused.
Posted on: 2011/6/1 23:28
Re: What coil with pertronix
Pertronix will say. Early units could.not do a high energy coil, but probably newer prtronic can. Keep in mind tjat gt40 is no stronger tham 1980s nissan ei coil.
Posted on: 2011/6/2 0:05
From Sydney
Yea i like the alternate mounts of the small transistor coil and the size of it.
Posted on: 2011/6/2 6:54
From Sydney
You can run the differnet style coil [e.g non oil cooled type] without any problem, Just be sure to varify that your pertronix setup is suited to the [for example sake] GT40 or GT40R coil. Basically the the pertronix unit will either prefer to run at 9volts or is able to handle 12v.
I also run a pertronix setup and still retain the ballist resistor.
Posted on: 2011/6/2 7:43
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Sydney
The pertronix needs 3ohms which the gt40t is and it can handle 9-12 volts.
so....... it should be ok.
I will get one next pay, i think they are like 80 dollars or something.
I just like the cleaner look, not looking for a performance gain.
Posted on: 2011/6/2 7:56
