(1) 2 3 »
ESTYRE'S SHED CLEANOUT !
From mandurah
Cleaning up my shed ,and trying to finish my motor
I've got
Clutchpro organic std replacement clutch ,has maybe 100kms on it if that $70 with new throwout bearing
GX double valve springs ,nearly new aswell ,around 150kms on then ,with retainers and collets SOLD
L series twin su carbs on a manifold with linkages $100
Locked 120y diff ,bw ,some brake bits missing $$ best offer
Dgav weber ,spotless jetted roughly to suit a series $100
T25 turbo ,welded gate ,some shaft play $100
V27 turbo ,with t25 adaptor plate ,very little shaft play $250
Stewart warner ,AFR gauge ,with bosch 3 wire heated sensor and brand new weld in bung ,gauge is brand new but sensor is used but in working order $150
If you need something ,just ask I might have it
Posted on: 2011/6/29 8:46
Edited by estyre on 2011/6/30 4:29:35
Edited by estyre on 2011/6/30 15:55:43
Edited by estyre on 2011/6/30 15:59:04
Re: ESTYRE'S SHED CLEANOUT !
From Tasmania
Any dellorto bits???
Posted on: 2011/6/29 9:15
Proud member of " The Tasmanian Datsun Owners Group"
From mandurah
I had a set of 4 32mm chokes but im sending then to nigel ,ive got a box of weber stuff ,so if you need any weber stuff I might be able to help
Posted on: 2011/6/29 10:04
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Tasmania
I have a feeling that I know where those Chokes are going to end up!
Posted on: 2011/6/29 10:12
From Nations Capital, Australia
On your carbies wombat?
Posted on: 2011/6/29 10:17
From Tasmania
I sure do hope so!!!!
Posted on: 2011/6/29 10:21
From mandurah
Sorry wombat ,dunno who levey sold them too
Posted on: 2011/6/29 10:23
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Haha. I was eyeing them off too on Levey's thread.
Posted on: 2011/6/29 10:25
From Tasmania
he is selling them to ME!!!!
Posted on: 2011/6/29 10:26
From mandurah
Oh ok
Posted on: 2011/6/29 10:27
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
(1) 2 3 »
