distributor install???
From vic
hi i was wandering if your supposed to install a dizzy at 0 tdc or 5 btdc as it says on tech wiki?
mine is installed on 0 degrees?
Thanks!
Posted on: 2011/8/12 1:58
Re: distributor install???
What does your glovebox owner's manual say? It might say 7 or 8 degrees before TDC.
Posted on: 2011/8/12 2:41
From vic
it says 7 deg!
so does this mean you have the crank on pistom one compression then u put on 7degrees then install the distributor with rotor pointing at number one point?
i installed mine a 0deg and was timing it by just advancing or retarding the distributor!
Posted on: 2011/8/12 2:46
From Melbourne, Australia
You're doing it the right way. You put the dizzy in at TDC cylinder one and then advance/retard via rotating the dizzy.
I'm pretty sure going one tooth either way will put it way over 7 degrees advance or retard.
Posted on: 2011/8/12 2:50
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From vic
hi thats what i thought but in the tech wiki it say put to 5deg btdc then drop the dizzy in were as i do mine at 0deg!
http://datsun1200.com/modules/mediawi ... le=Installing_Distributor
Posted on: 2011/8/12 2:52
It says that because due to the 'twist' in the dizzy gear, it will rotate back around to TDC as it drops into place.
That makes sense now.
Posted on: 2011/8/12 3:19
Current Fleet-
From vic
hi thanks i just put the crank to 7 deg and put in the dizzy and know the car idles very good before it had very low vacuum readings 14 hg and the revs would go up and down
know it sits at 800rpm steady and has 18-19hg vacuum readings!
must of been off a bit before i think!
Thanks!
Posted on: 2011/8/12 5:32
Glad to hear it is working now. You put the crank just before TDC, then install the distributor.
Altnernatively you can put the distributor in at TDC, then move the crank to 5 or 7 BTDC and rotate the distributor so the points are just opening. If you have enough room to rotate it.
Either way will work.
Posted on: 2011/8/12 5:56
From vic
thanks im happy i got it running!
Posted on: 2011/8/12 6:20
From Malaysia
actually the real procedure would be putting the crank at 5 BTDC, and checking the cam position by feeling the rocker at first and second. if the rocker arm rocks (tight), turn another round. if the rocker arm feels loose, then put the distributor. you dont want the distributor to be 180 degrees off. alternatively, if you just put the distributor at TDC, and start the engine, if the engine backfire, just swap the plug lead 1 and 3. your lead position looks 180 degree off compared to standard now, but it still works.
pardon me for my bad english :)
Posted on: 2011/8/12 7:42
