B120 120y front disc brake conversion
From Sydney, NSW
Well that was a mission hahaha...
nah it wasn't that bad actually, only things i had to do was get new brake lines made up, because the others were in pretty bad nick and i couldnt even blow through one of em lol.
so two new flexible brake lines from the callipers to solid lines set me back $90.
Also callipers were a bit tight, so i stripped them down, greased all the slides and made sure there was no pitting on the pistons.
The only prob i had was after i put it all on and went for a test drive the brakes were coming on and staying on. supafatto and 1200rc helped me out there and turned out that for disc front end with the 11/16 master cylinder needs to have the check valve removed... but all on now and works a treat... good improvement whilst still saving pennies for whole MADDAT front end lol
Posted on: 2012/9/2 7:28
Daily: 2000 Holden VX Calais 5.7L GenIII
Datto: 1972 Datsun 1600 L20B twin 40 DCOE Webers
Re: B120 120y front disc brake conversion
Good stuff. So better braking now?
Posted on: 2012/9/2 8:42
From Sydney, NSW
yeh pedals alot harder and pulls up heaps better...
Posted on: 2012/9/2 9:06
From Sydney, NSW
Sweet the new springs rocked up today for the 120y struts... wasnt gonna change em but thought stuff it might as well lol
now to pull it all back out again hahaha
got a set of "Low" King Springs which should drop it about 30mm and as u can see by the pics it needs it lol
especially when the back tyre is inside the guard...
Posted on: 2012/9/3 8:09
From The BV in South Aus
I'm about to do the same thing in my sedan and wanted to know how it all worked out.
Are you happy with the ride and ride height with the king springs?
Did you replace the strut inserts? Same or shorter?
Got any photos?
Thanks, Tom
Posted on: 2012/11/10 7:19
Nice work! What calipers are those?
Posted on: 2012/11/10 9:01
they look like sigma calipers i think
Posted on: 2012/11/10 10:18
www.datsun1000.com
Current Dato -
68 B20 ute
Previous Datos -
ca18det 1200 ute 180rwkw
Stocko 1200 wagon
From Sydney, NSW
Lazy: yeh mate it drives well, happy with the ride height,and i used the same inserts... although doin the maddat front end now as i just bought some shortened stanza struts with coilovers.
dd: I bought these struts under the assumption they were stock 120y struts and calipers lol so if thats not the case then im not sure what calipers they are haha
Posted on: 2012/11/11 1:12
