2.5 degree camber rear axle
cut-n-weld for negative camber
jpg  1.jpg (29.32 KB)
174_5493cfd9d2325.jpg 600X337 px
jpg  2.jpg (30.58 KB)
174_5493cff52ab33.jpg 600X337 px
jpg  DSC_0083.JPG (129.62 KB)
174_5493d00a67169.jpg 1268X713 px
jpg  DSC_0185.JPG (145.44 KB)
174_5493d019f0a75.jpg 1268X713 px
jpg  DSC_0155.JPG (104.93 KB)
174_5493d0b1c8da7.jpg 1024X768 px
Posted on: 2014/12/19 7:16
Re: 2.5 degree camber rear axle
From Perth WA AUS
impressive, surely this mod will cause a lot more wear on the diff center??
Posted on: 2014/12/19 8:20
Datsun 1200 2Dr sedan.
He says more than three years of driving with no problems ...
Posted on: 2014/12/19 8:27
From Perth WA AUS
Cool, that mod would look awesome on any 1200 .
Posted on: 2014/12/19 11:01
From sydney australia
The end of the axles are machined slightly so the top edge of the axle is always parallel to the spider gear, while the bottom sits up. I believe Jeff Hanson ( Rfast) has done this to the axles in his Sunny. The 'semi mythical' Stanza H190 housing had this done. I know of a local Stanza rally driver who threw away his rear end because he thought it was bent. Wish he'd thrown it my way. He now runs a Hi-lux diff thats been bent for rear camber.
Posted on: 2014/12/19 22:50
